Export a Subassembly from Polyline to Subassembly Composer
kboldt
kboldt
I'm wondering if there is any way to create a subassembly from a polyline, using the command in C3D, but then take that simple subassembly, and export it to a pkt, so that it could be opened in Subassembly Composer, and you could then add parameters and targets etc.
If this isn't possible, it would be a great feature add, so that we could draw out the basic shape/linework of a subassembly in AutoCAD, without having to create each point and link in composer. Then you would just be able to add/edit the parameters and targets that you need to make it a more dynamic subassembly.
KMercier_C3D
No currently possible but an interesting idea to suggest in Civil 3D Ideas. The only real difficulty I see with this is that all the points would be defined as Delta X and Delta Y whereas if you were defining them directly into SAC you may define some based on slope criteria.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
kboldt
I agree that it could make as much work as it it would save. I was just hoping that there was a way, so that it would give me a starting off point.
Thanks for the reply.
Cheers!
Strator
That would be a very urgent possibility. I could save a lot of time. I can imagine that composer clould import some difficult geometry maybe. Hi developers, wake up!
ChrisRS
@Strator wrote:
... Hi developers, wake up!
THis is a user sipported forum. There is very little Autodesk participation in this forum. @KMercier_C3D pointed @kboldt to the Civil 3D Ideas forum, which is to best place to make a suggestion like this and for other users to support it. The Ideas forum reportedly gets more attention from Autodesk.
Christopher Stevens
abd_sed
I agree, 2024 still have the same interests.
