I have designed a sewer network on civil 3d and i want to calculate the volume of excavation which would be required for the pipe network. I have elevation of ground but cant find a way to calculate the total quantity of Excavation required.
Hi
2 method
1- grading volume : (you already have bottom elevations, existing elevations)
2-use expression (you already have width , depth of excavation , )
see attached photo
In your formula, why did you add the inside diameter of pipe to the outside diameter of pipe?
& where does the excavation depth come from?
Bill
Hi
I give him gust an idea to do that.
demonstrate expression method see photo attached.
excavation depth = ((maximum cover+minimum cover)/2)+pipe outer diameter or width
Hi @Anonymous ,
3rd party application? Urbano Visio. Look the YouTube video: https://youtu.be/RrckpaeVZWE
Drazen
