- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In Fitting properties, there is an Elevation property, and it can be different from the Invert Level ( or any other properties) for the connecting pipe.
So exactly what is the (physical) meaning of the Elevation property of the Fitting? To me it's not meaningful at all because the actual fitting z position will ( and must)be overridden by the connecting pipe's z level. Referring to the screenshot here, one can also infer that that is meaningful is the pressure pipe invert level and not fitting elevation.
What is your take on this?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
Ngu Soon Hui
