- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please help!
I've seen a few people posting about this problem, but nothing has helped me. I understand the difference between PASTECLIP and PASTEBLOCK, Ctl+V, and Ctl+Shift+V. This problem ONLY happens when more than one drawing is open, it doesn't matter which drawing is open, old ones or new ones, it only happens when more than one drawing is open at the same time.
- SDI command is turned to 0
- I tried keyboard copy paste (ctl+c, ctl+v)
- I tried the right button copy and paste
- I tried the commands COPY - PASTE, COPYCLIP - PASTECLIP, COPYBASE - PASTEORIG, COPYBASE, CUTBASE
- I had Civil3D and Map3D, it happens in both, I uninstalled Civil3D, still happens in Map3D
- AutoCAD updated to the latest version also happened in the version before
- Windows is fully updated
The biggest problem is that once I save, everything looks fine, but when I close and open the drawing again, all those blocks are gone, even though the drawing preview (AutoCAD's Recent drawings in the Start tab) shows all the blocks as if they were there, all gone.
The workaround is that I have to XPLODE the blocks twice. If I explode the blocks once, they will be gone once I save, close the drawing, and open it back. If I explode the blocks twice, they will be there. In a regular drawing, I may have more than 25,000 lines that can turn into 60,000 lines or so, the workaround is not always too efficient.
This error only happens when more than one drawing is open.
