event log when opening files
luc.poulin
luc.poulin
Hello All
I'm trying to figure out why, when I open a C3D file, the event log show me 105 events. Where are they come from?  I have nothing obvious that elate to this, DS  are OK , Xref nothing broke....
I'm also intrigue why always 105, but I'm sure once I figure out why I got events, I will fins the source
So I would like to heard  if you already have the same and how you manage to find the source of those events
Thank you
Have a god weekend
Jeew-m
I can guess few reasons.
One is you have data shortcut objects, specially surfaces where the connection is no longer available. You can synchronize or validate references to find out and update the references.
The other thing I can guess is you have surfaces created by importing land.xml. But now the land.xml are not in the original place. So civil 3D gives you a not of that. Usually an error note. By updating land.xml location you can solve this issue.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
luc.poulin
Thank you Jeewana
Will check with the production regarding the land.xml
