Esri Imagery doesn't work
graziellapereira
graziellapereira
When I'm using the geolocation and turning on ESRI Imagery nothing appears and my project suddenly lags a lot but if I use all the other ESRI maps it works just fine.
I tried to use a different computer but I have the same problem, has this happened to anyone recently?
nicholas944saul
Hello! openskycc com
Yes, others have recently experienced the same issue with ESRI Imagery not loading and causing heavy lag, while other ESRI basemaps work fine. It’s a service-side problem rather than your computer or project setup. The best workaround is to temporarily use other basemaps, check ESRI’s ArcGIS Online Health Dashboard for service status, and report the issue on ESRI forums if it persists.
