Error: "Script Control (msscript.ocx)" when creating pipe network
Joe-Bouza
Mentor Mentor
Joe-Bouza
Why after  2+ years of running this software has this crept into my installation?
And the fix (less the clean uninstall install) doesn't work
>>>KB Fix<<<
So now I have 2014 & 2015 installed and neither work. Beautiful... Just ...Beautiful. I'd have to have my head examined to install 2016
Not for nothing but I have better things to do with my life then do clean uninstalls. Why doesn't the "Autodesk Unistall" tool do it all? Thats Rhetorical
Joe Bouza
AlmasSuljevic
Autodesk Support
Autodesk Support
Hi Joe,
This is a Microsoft file and error caused by the script file file.  I have seen wide variety of different solution starting from registering the OCX fiel to clean reinstall of Operating System  and there is hard to tell which ones worked. This is a typical list of suggestions we offer to users who have encountered this issue:
Install the script control: http://support.microsoft.com/kb/184739
http://beingcivil.typepad.com/my_weblog/2013/01/msscriptocx-error.html
https://forums.autodesk.com/t5/autocad-mep-general-discussion/msscript-ocx-autocad-mep-2012/td-p/357...
Look for
Good news.  We have been working on this MSscript.ocx issue.
We recently discovered the cause and developed a solution.   Would you please have a look at folder: C:\Program Files (x86)\Common Files\Autodesk Shared, and verify the existence of the following files.
Aec32BitAppServer.dll
Aec32BitAppServer57.exe
Aec32BitAppServer57.tlb
I hope some of it helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Joe-Bouza
Thanks Almas.
Pardon the frustrated rage. One step at a time.
Joe Bouza
JEFFYEARY7710
Hi, I'm dealing with the same issue while trying to create a pipe network.
I have gone through all of the steps of first repairing my Civil 3D 2013 install, then I went through the steps of editing/updating my sytem registry as it relates to correcting the "msscript.ocx" file.  The only thing I've come up short on is that I do appear to be missing the
Aec32BitAppServer.dll  file in my C:\Program Files (x86)\Common Files\Autodesk Shared folder - wondering if you can recommend a safe/reputable source to aquire that file from? (every source I seem to come across wants me to download their "DLL Error Scan Tool".  My concern is that I will end up with some kind of malware being installed while just trying to fix an issue in Civil 3D.
Can you please recommend a safe/trusted source to aquire the  Aec32BitAppServer.dll   file?
Thank you,
Jeff Y.
64 bit, Windows 7 Professional, Autocad Civil 3D 2013
Joe-Bouza
Hi Jeff
Sorry I cant offer much guidance on this. I got so frustrated that I reformatted my hard drive
Joe Bouza
Jeff_M
Jeff, it should be in the ZIP file attached to this message: https://forums.autodesk.com/t5/autocad-mep-general-discussion/msscript-ocx-autocad-mep-2012/m-p/3576... be sure to Unblock the downloaded ZIP before opening it.
