Error Performing Edit
ethevis
Observer Observer
ethevis
Observer
Observer
Hi all, I've been trying to paste both my existing surface and corridor surface onto a new finished picture, but no matter what I try I continuously get the 'error performing edit' message. I've followed all of the steps I could find for workarounds/finding the problem, but nothing has seemed to work for.
Does anyone have any new recommendations for figuring out the issue?
Drawing is attached below. (This is probably done very poorly, I am an undergraduate just playing around)
Pointdump
Hi Ella,
Welcome to the Autodesk Forums.
Thanks for posting your drawing.
I get same as you. I suspect it has to do with this error message:
"Macro file not found at original path specified in subassembly."
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
ethevis
Observer
Observer
David,
Thanks for your reply! Can I ask where you're seeing this error message? When running it myself I get no other pop-up aside from the "Error performing edit."
Additionally, would you know to fix that error message?
Pointdump
Ella,
Open your drawing by using command RECOVER. If you don't see "Events", use command SHOWEVENTVIEWER.
I'm not well-versed in Corridor creation, so I'm not sure how to fix that error, but you can extract the 43,405 points from the corridor surface and then add them to your EG surface.
Drawing attached.
Dave
Dave Stoll
Las Vegas, Nevada
navya_gelli
Hello, @ethevis,
Just checking in—did the responses shared by @Pointdump help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Navya | Community Manager
