Error opening Hydraflow files for Civil 3D 2023
amr_bazaraa
1 620 Visites
6 Réponses
Message 1 sur 7
amr_bazaraa
Files saved in Hydraflow cannot be opened again. Whenever you try to open the stm file, you get the error message "Error loading ...*.stm"
The Hydraflow file contains only a few pipes and has a size of less than 15 KB, so size is not an issue.
I have tried saving 4 different files and non of them can be opened again.
Hydraflow files and Civil 3D are the same 2023 version
Attached is the error I get and the original file
0 J'aime
1 621 Visites
6 Réponses
Message 2 sur 7
matt_anderson_pe
Likely too old.
The header of the STM file is:
""Storm Sewers for AutoCAD Civil 3D 2015"
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
0 J'aime
Message 3 sur 7
amr_bazaraa
Hi Matt,
That is a very good observation but how is that possible, I do have Civil3D 2023 and I am launching Hydraflow from my current Civil3D 2023. Is it possible that a Civil3D 2023 opens Hydraflow 2015. Sounds very strange. Don't you agree?
I open Hydraflow from Civil3D 2023 by choosing from the menu, Analyze / Design / Launch Storm sewers (Hydraflow)
Any suggested solutions?
0 J'aime
Message 4 sur 7
pendean
Community Legend
Community Legend
@amr_bazaraa wrote:
...I open Hydraflow from Civil3D 2023 by choosing from the menu, Analyze / Design / Launch Storm sewers (Hydraflow)
Have you seen this yet
https://help.autodesk.com/view/CIV3D/2023/ENU/?caas=caas/sfdcarticles/sfdcarticles/Open-file-error-w...
And what if you...
https://help.autodesk.com/view/CIV3D/2023/ENU/?guid=GUID-5E6FCD9D-2A93-4AD5-A1E4-48077FA36CC3#:~:tex...
0 J'aime
Message 5 sur 7
matt_anderson_pe
At some point after Autodesk purchased Hydraflow, the file format was modified, but Hydraflow File>Open was not backward compatible.
Interesting to use SSA to import, and then export to STM to upgrade the process.
Inundar, LLC
0 J'aime
Message 6 sur 7
lim.wendy
Hi Amr,
Thank you for submitting your question in our discussion forums Have you had a chance to look over the suggestions provided by our experts?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 J'aime
Message 7 sur 7
athompson65Z89
I'm encountering a similar issue. Using Civil 3D 2024, I exported a pipe network in December of 2025 and everything is fine to edit the Hydraflow. However, if I export the same network today, it will not let me make global edits in Hydraflow.
Additionally, I've noticed the exported STM from December 2025, if you look at it in notepad, the top line reads "Storm Sewers for AutoCAD Civil 3D 2015", whereas the export from today reads "Storm Sewers for AutoCAD Civil 3D 2012". I'm not opening the file in a different version as c3d2024 is the only version I have installed on my computer.
I cannot find anywhere in settings, etc. where a export version would be set.
Here is a comparison of the same network being exported. The format is different and it has changed some of my values.
0 J'aime
