Error Message "Current Alignment Has No Elements"
robert.conwayC5N5Y
robert.conwayC5N5Y
Hi, i was trying to insert a turnout into a rail alignment and its coming up with an error message saying "Current alignment has no elements" i did a search for this issue and i tried to audit the drawing for errors and there was none and i checked masking. It was working fine for me before i was able to insert turnouts, im not sure what has changed in the meantime. I would be grateful for any help / suggestions. See attached image of error message. Thanks, Rob.Civil 3D Error Message.jpg
tcorey
During training I often see students will create an alignment and then close the toolbar. When they want to edit that alignment, they mistakenly use the Alignment Creation Tools again, instead of selecting the existing alignment and using Geometry Editor.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Nilesh_Chaudhari
Hi @robert.conwayC5N5Y ,
Can you try copying all the drawing data to the new drawing?
Also, you can try copying the alignment and edit it again?
Nilesh Chaudhari
Product Support Specialist
Probably already sorted out but just in case.
I had the same issue and was because accidentally i changed my alignments from "Rail" type to "Centerline".
After returning to "rail" type the error message disappeared
