Error creating survey database
mark7QN5N
Message 1 of 13
mark7QN5N
Just recently tried to create a survey database and got the following error message, "The survey database does not exist and could not be recreated". If I go to an old survey database that worked properly in the past I get an error that it is not readable. The survey databases are stored on a shared server, if I set my working to my desktop I get the same error. I'm working on Windows 10  and tried unistalling the SQL server and then re-installing with no changes.
Replies (12)
Message 2 of 13
rl_jackson
Hard to say without a version of C3D, but you might try the .NET framework as well.
Rick Jackson
Survey CAD Technician VI
Message 3 of 13
mark7QN5N
I'm on Civil3D 2017. I did try to repair/reinstall the .NET Framework.
Message 4 of 13
rl_jackson
Is there a possibility that the database was opened in C3D2018?
Rick Jackson
Message 5 of 13
mark7QN5N
No. I only have 2017 and have not purchase 2018.
Message 6 of 13
rl_jackson
OK lets start with a couple of things here.
1. can you create a new database? in the current location set.
2. can you copy the database locally to you C drive and access it?
3. When you looking in your working folder is there a broken pencil symbol, eluding to read-only status?
Rick Jackson
Message 7 of 13
SMorykin
@mark7QN5N - try this from the AKN
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
or this (we've had to use this particular sequence to fix it a few times with our machines)
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
Message 8 of 13
mark7QN5N
rl Jackson -   1. No I get the error when I try to create a new SDB.
2. It does appear to work if I copy it to my local c:\ and open it that way.
3. I don't see any broken pencil symbols.
Thanks.
Message 9 of 13
SMorykin
Are there any special characters in your project path?
Message 10 of 13
mark7QN5N
nope, just numbers and letters example 13517001 SDB
Message 11 of 13
rl_jackson
If you can create a database locally - I would start looking at permissions.
Rick Jackson
Message 12 of 13
mark7QN5N
I've asked our IT guy and he assures me I have admin rights to all the files. I'm a standalone user and I'm the only one who uses the server. It worked fine last week. Any idea what folders I need the proper permissions for? I've looked and it appears that I have the permissions but maybe I'm missing one. Thanks.
Message 13 of 13
Partenheimer
I had this issue on two Windows 7 computers (all of our Windows 10 computers don't have this problem).
I found a clue to my issue on this 2011 Being Civil blog post:
https://beingcivil.typepad.com/my_weblog/2011/02/unable-to-find-the-requested-net-framework-data-pro...
My solution:
Go to my Civil 3D installation image and locate the file: SSCERuntime_x64-ENU.msi
As described in the blog, I ran it and, on the second screen, selected "Repair".
This worked on both of my Win 7 computers.
Michael Partenheimer
