- Mute
- Permalink
- Report
In one of my files, I have many saved views (20 to 30). On some or all of them, when I select a named view, the viewport will zoom in to the desired view, but almost instantly zoom to extents. Any ideas what can cause this?
I am using Civil 3D 2024 with 2024.4 update.
I have done the following and got no results.
I restarted the program.
I ran recover on the file. No errors showed up.
I turned object snap off.
In a copy of the file, I deleted most of the views, to see if the number of them was causing the issue.
I had a coworker open the file on his computer (with version 2023). He got the same results.
Thank you in advance for the input.
