Elevation
Elevation
savime
Elevation
savime
Community Visitor
Community Visitor
Why does C3D assign an elevation of -1.0000E+20 to poly lines created from points with elevation of "property not set"?
AllenJessup
Can you post an example drawing? An elevation of -1.0000E+20 would put you through the planet and probably outside the solar system. I'd need to see that to get a handle on it.
Allen Jessup
CAD Manager - Designer
Pointdump
Hi Mark,
Where are you seeing "property not set"? I've never seen that.
Usually, a polyline created from COGO points takes the first point's elevation.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
AllenJessup
Dave,
I believe the OP was referring to this. However I don't experience what the OP is saying. Starting a PL from that point gives me a PL with 0.00 elevation.
Allen Jessup
Pointdump
Hi Allen,
I tested just now creating a polyline by snapping to COGO points with "Property Not Set" elevations. I get same as you, elevation = 0.00.
Dave
Dave Stoll
Las Vegas, Nevada
chriscowgill7373
I thought I remember an issue way back when that if you were not looking in true plan view, like it was slightly rotated in 3d that the elevation wouldnt work correctly?
Have you confirmed that your drawing is in PLAN using world coordinate system before trying to add your polyline?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
rosie_lucas1
Hi @savime
@AllenJessup, @Pointdump, @chriscowgill7373 asked some follow up questions to better assist you, have you had the chance to look at them? Please share any available information so the community can assist you further.
If you found a solution to your question already, could you provide it? It would be beneficial to other community members who might come across the same issue later on.
All the best,
Rosie| Community Manager
Rosie | Community Manager
