Civil 3D Forum
Elevation Analysis
16 REPLIES 16
Message 1 of 17
ZackTheisen
811 Views, 16 Replies
Elevation Analysis
I am trying to creating a color scheme to show color shading for three different elevation ranges: 2480-2490, 2490-2494 & 2494-2495. I have successfully created those ranges with the desired colors, but it is also shading in everything outside of the ranges that I have set. I am having a hard time figuring out how to NOT color in the elevation ranges that I have not set. Any help on how to turn off that off would be great!
Screen shot attached for reference.
TIA
16 REPLIES 16
Message 2 of 17
BrianHailey
in reply to: ZackTheisen
Can you share a file that is showing this behavior? The elevation banding should only fill in the areas that you have in your ranges.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 17
BrianHailey
One quick thought, make sure your surface style isn't displaying anything but the elevations.
GEI Consultants
My Civil 3D Blog
Message 4 of 17
ZackTheisen
in reply to: BrianHailey
I am not able to get the file size down small enough to attach a copy of it. I did try having only the elevation turned in, but it still had everything colored.
Message 5 of 17
Joe-Bouza
you got a OneDrive?
Joe Bouza
Message 6 of 17
ZackTheisen
in reply to: Joe-Bouza
Message 7 of 17
Pointdump
Hi Zack,
Thanks for posting your drawing.
Your drawing is only 34.5MB. This forum will accept up to 71MB files.
I'm not seeing the problem you layed out.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 8 of 17
ZackTheisen
It was a lot bigger, but I changed a few settings and the size by about 2/3. Thanks for noticing!
Message 9 of 17
Pointdump
Gonna need the Tiff too, to re-build the surfaces.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 17
ZackTheisen
in reply to: Pointdump
These are the 2 .tifs for the area that I am looking at currently.
Message 11 of 17
Pointdump
Zack,
I get same as you.
That dark blue you see is Layer C-TINN-VIEW. Here I changed that layer's color to white.
Your surfaces are grid surfaces. Have you tried TIN surfaces?
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 17
Pointdump
Zack,
If you create a TIN Surface it works as expected. I don't know why Grid Surfaces behave like that.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 17
Joe-Bouza
Pretty cool, right 👍😎
Joe Bouza
Message 14 of 17
Joe-Bouza
What are grid surface for? They seem to not abide by many typical surface routines
Joe Bouza
Message 15 of 17
Pointdump
Hi Joe,
"What are grid surfaces for?"
I haven't done much with Grid Surfaces, so I don't know a lot about them. There must be some things that a Grid Surface can do better than a TIN. Like creating a mesh for use in other programs.
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 17
ZackTheisen
Thanks for the help! I had created the surface two ways, the first time I created a .tin surface and then added the .tif fil0e. I had some issues with the contours showing so I fiddled with the drawing and reimported the surface but this time using the "Create Surface from DEM..." option. It never dawned on me that it was a Grid surface and not a tin surface (even though it is stated ion the surface name). It all works perfectly now!
Message 17 of 17
Biggest thing grid surfaces are used for is working with DEM files.  USGS Digital Elevation Map (DEM) creates points on a grid, so you are not trying to get every wrinkle in the ground modeled, you are just working with the area wholesale.
This is great when you are working with city or township sized data, but not very useful for average day to day surface modeling where we need to model every wrinkle in the ground.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Rail Community
