Civil 3D Forum
Editing Point Settings
1 REPLY 1
177 Views, 1 Reply
I am trying to change a points settings so that, once downloaded into Civil 3D, said point populates as one of our blocks rather than its existing "x". Where would I go to change this so that I only have to change it once, instead of manually doing it in each drawing under point properties? Would like it to do it automatically for every future survey.
1 REPLY 1
rkmcswain
rkmcswain
You need to set up one or more description key sets (DKS).
Each code in your DKS can point to a point style, which in turn can reference a block or internal point marker.
Once you do this, save this as your template file (or do this work in your existing template) = then you'll never have to do it again.
ref:
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
ref:
Rail Community
