Editing modifiers in Text Component Editor
Hi guys,
HNY2021!
I am finding it difficult to edit the modifiers in the text component editor, specifically for "General Segment Direction" as I want to omit the direction initials. For example, when I label a line, I would like to see the line labelled as 80°12'15" and NOT N80°12'15"E.
Hope to get some positive feedback on this thanks!
Regs, david
Jeff_M
I've never heard of such a request or need. The only way I canthink of would be to label as Azimuths instead of bearings.
MMcCall402
Hmmm ... make a block of a small wipeout, add it to the label style twice, anchored to each end of the bearing text component, and then add offsets to make them overlap the unwanted N,S,E,W.
Edit:
Better idea:  Add two text components. The content of the text is just a space. Add a mask to each then anchor them of each end of the bearing with appropriate justifications to the text and the anchoring to make them overlap as needed.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
AllenJessup
As @Jeff_M said. In the NE quadrant you could use Azimuths since 80°12'15" is equivalent to N80°12'15"E. However that doesn't work in any other quadrant. 80°12'15" is not equivalent to  S80°12'15"W. The Azimuth in the SW quadrant would be 260°12'15".
I don't see any way of doing what you wanted other that the suggestion by @MMcCall402 .
Allen Jessup
CAD Manager - Designer
Jeff_M
My turn for a "better idea" 🙂
Use an expression to format the Azimuth as a direction:
{General Segment Direction},IF({General Segment Direction}>=pi & {General Segment Direction}<=pi*1.5, {General Segment Direction}-pi,IF({General Segment Direction}>=pi*1.5 & {General Segment Direction}<=2*pi, 2*pi-{General Segment Direction},{General Segment Direction})))
I named mine "Directionless Direction", set the Format result as Azimuth, then created a style using all 3 types to verify the output (Azimuth, Directionless Direction, Bearing) and this is the result:
MMcCall402
I bow to the master.  Elegant solution.
Mark Mccall
CAD Mangler
Linkedin
