I have generated Multiple Section Views from 2 overlapping surfaces (proposed & existing) using sample lines.
I need assistance with editing the section views graphs.
- need to change the colors of the data shown on the graph
- need to change the range of the elevations shown on the graph.
- need to be able to update the sample lines every time I am opening the dwg.
Anyone familiar with this case?
Thank you in advance!
Solved by Jeew-m. Go to Solution.
These are my suggestions.
Go to section view group properties --> sections tab --> Styles column
You cant change it as a group. You need to do it as individual section views
Make the corridor/surfaces as Rebuild Automatic
Thank you so much Jeew!
About the elevation range, I need to present view sections for more than 8000 feet with the appropriate elevations shown. It will be time comsuming to generate individual views for every sample line.
Attached is a printscreen. On the left praph is the desired elevation range but autocad generades the graph on the right.
Any ideas on how to proceed?
Thank you for your patience!
I cannot walk you through this but if you can generate one section you can generate all sections at once.
(It normally takes me some trial and error before I get it like I want it.)
Practice changing the various styles, etc. with just a few sections until you get it like you want.
Bill
