I have a point in my surface that has a bad elevation. My question is this, I unlocked the points and edited the point containing the bad elevation and I am wondering why my surface is not automatically updating. I have a breakline in the surface that uses the "bad" point and by editing the point to the correct elevation, I was assuming that my surface would automatically update, which did not happen, so I selected the breakline and edited that also to the correct elev., and the surface still did not update until I chose "rebuild surface" even though I had "rebuild surface automatically" turned on, so I am a bit confused. Please advise......
Solved by mathewkol. Go to Solution.
