I have a pipe network defined. When I go to edit the pipe network using the pipe network vista the panorama is empty. When I initally click on the pipe network vista, I can see the "table" being populated, but both the Pipes & the Structure tabs become empty. I just started using C3d 2010 BTW
Paul
I have pipes and structures. Right now I can only edit the network by editing the pipe or structure propeties, not thru the network vista.
Have you noticed this in any other the other Panoramas? The Alignment one, for example?
How about in other files - does the issue persist here? Try one of the tutorial files (C:\Program Files (x86)\AutoCAD Civil 3D 2010\Help\Civil Tutorials\Drawings)
I don't think the OP mentioned whether or not the latest updates are installed...
I would look into at this as well.
John
John Mayo
