when i open a cad drawing in error occurs
and my eagle point do not work propoerly lie creating sheet which my plan did not reflect in sheets etc pleas hel me out to resolve this problum.i tried on other PCs same problum occurs. thanks
THE FILE CREATES PROLUM IN EAGLE POINT ONLY IN CAD ITS GOOD
Not sure what your error is in Eagle Point, but I get no errors in C3D13 nor are there any errors found with an audit.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
What version of Autocad or CIvil 3d are you trying to run with Eagle Point 2009?
It never worked for me beyond the 2010 dwg file format, which was used in Autocad releases 2010 - 2012.
Read THIS thread and see if it helps.
Allen Jessup
CAD Manager - Designer
Allen Jessup
Eagle point Civil will not work beyond Civil 3D 2012 and Eagle Point stopped supporting that software in conjunction with Autocad 2013 release. Look into the Surveyors Companion and Data Reduction modules if you wish to continue to use Eagle Point in your workflow.
using auto cad 2007
using auto cad 2007
