Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Dynamo Missing Node
3 REPLIES 3
Mahmoud-elsayed145
440 Views, 3 Replies
Dynamo Missing Node
I'm using dynamo civil 3D 2022 and trying to import points sheet from excel using writing a code block and Data.openXMLImportExcel node is not existing. Any thoughts how to find it or using a replacement?
Labels (1)
3 REPLIES 3
Hi Mahmoud,
Have you updated your 2022 and the library that node is in?
If that fails, then a good place to ask is the >>>Dynamo for Civil 3D Forum<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
How to update?
Mahmoud,
Data.OpenXMLImportExcel is in the main Library. I was thinking at first that it was in one of the "packages".
If you update your Civil 3D 2022 that should also update the main Dynamo Library. (Or was Dynamo a separate install in that year? Look for updates in your Autodesk account.)
I don't have 2022 to test. Here is a screenshot of my 2024 library. It's under "ImportExport". Or you can do a search for "Data.OpenXMLImportExcel".
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
