Dynamo for Civil 3D not showing up in program despite license permissions
Spector567
Spector567
I have a full AEC license and can confirm that it was working because project explorer works fine.
However, Dynamo for Civil 3D is not showing up in my C3D 2022 installation anymore.
In the process of trying to solve a mysterious Set properties problem. I uninstalled both Civil 3D 2022 and revit 2022 and than reinstalled C3D 2022. However, now Dynamo will not show up on the manage tab and the commands do not work.
Any ideas what is going on here?
Jeff_M
I am also not finding Dynamo on the Manage tab in C3D 2022. No panels have been hidden.
Jeff_M, also a frequent Swamper
Pointdump
Hi @Spector567,
Looks like others are having that problem. Read more about it in the >>>Dynamo Forum<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Udo_Huebner
New in Civil 3D 2022: Dynamo for Civil 3D is now integrated into the main installation of Civil 3D.
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Civi...
Therefore, I assume that a separate entry at manage.autodesk.com is no longer necessary.
But the second issue  @Jeff_M pointed out, dynamo is missing, when uninstall an then reinstall Civil 3D.
Gruß Udo Hübner (CAD-Huebner)
Jeff_M
Thanks Dave! @Pointdump reading the thread on the Dynamo forum I decided to try the uninstall, then use the MS Install/Uninstall tool to uninstall Dynamo for Civil 3D 2022, then install C3D 2022. That solved the issue for me. You may recall that I had a horrible time reinstalling C3D 2022 about 3 weeks ago. I had used the MS tool then as well, but it never dawned on me that Dynamo would need to be looked for to fix the uninstall separately.
rgrainer
i can confirm this. Went through it myself about 2 weeks ago. Hopefully this will be addressed in the upcoming  C3D release.
