Drawings Corrupted and Doubling in Sizw
Hello:
Has anyone experienced drawings being somehow corrupted and doubling in size?  We are working with very simple/small drawings (no C3D elements, only lines & text), but referencing them into a larger compiled drawing.  Each of our drawings are about 500kb, and contain around 200 elements at most.  Just simple lines, text and leaders.
If we have one of our drawings open in a session of Civil3D, and open an "infected" drawing and save..... the once clean and streamlined drawing doubles in size.  If you try and open the now "corrupted" drawing... it takes forever, and the drawing is totally sluggish and bogged down.  The element count in the drawing is still the same though.  Even after corrupted, the doubled drawing is only around 1,200kb, but it takes approx. 45 seconds to open.
I've attached a "corrupted" drawing here, so troubleshshoot with caution!
tcorey
This is likely caused by a known issue in Civil 3D versions 2013 through 2017. There are fixes for 2014 through 2017:
http://www.deltaengineeringsystems.com/support/
Read the second article, "Important technical note regarding Civil 3D"
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
BushW
Hi @Anonymous
Did poster resolve your issue with the great suggestions? If so, please reward the post that worked with a Kudos and pleases also mark a post or posts as Accepted Solution(s) that resolved the issue or answered your question.
Wendell Bush
Civil Infrastructure Technical Support Specialist
BushW
Hi @Anonymous
I am checking back to see if the previous post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solve your issue or answer your question.
Best Regards,
Wendell Bush
BushW
Hi @Anonymous
Here to help and thank you for doing so.
Wendell Bush
BushW
Hi @Anonymous
I realize this is thread is old but, I just wanted to inform you that I’ve just accepted your reply to your post as a solution with the understanding that this a solution to your issue.
If the response of @tcorey did not work as a solution, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
However, I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns I am here to help!
Wendell Bush
