Civil 3D Forum
Drawing Recovery Manager
5 REPLIES 5
AEC_Cadd
1222 Views, 5 Replies
Whenever I try to restore a drawing or delete it from the drawing recovery manager, I get a Fatal Error and the computer crashes. Anyone know where these drawings are stored so that I can go to that directory and delete them?
5 REPLIES 5
Jeew-m
in reply to: AEC_Cadd
Dear Friend,
Go to options and in files tab you have all the file locations.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
cwr-pae
I think what you are looking for should be a windows shortcut to a file named xxxxxx_recover.dwg on your C:\. There will also be shortcuts to the original file. So do a search in windows explorer of your C:\ for '_recover' and then right click and pick 'open the folder'.
Its possible the file will be named with nnnnn_recoverGWS.xml in C:\ProgramData\Autodesk\C3D 2018\MapCache.
I quit using recovery manager because of that frequent behavior. Recover the files manually and the delete the _recover.dwg (after saving with original name of course) then you should be able to remove them from the recovery manager. If not, I find if I close the recovery manager and keep working, I can delete the entries in the manager the next time I start C3D.
Joe-Bouza
OOTB location
%temp%
At the start button or win explorer
Joe Bouza
AEC_Cadd
in reply to: Jeew-m
Thanks, I'll give it a try.
AEC_Cadd
in reply to: Joe-Bouza
I'll try this as soon as I get a chance. Thanks for the quick reply.
Rail Community
