I have Civil 3D 2016. A drawing path is being displayed in both model space and paper space and it will not go away. I have tried regen and display options but nothing is working. I cannot click on the drawing link but it covers up my cursor when I hover over it. The same drawing path is shown in every session of CAD that I open regardless if said drawing is open or not. If i have other programs running on my computer and I pull them up, the drawing path hovers over the top of them as well. I have attached a screen shot of what it looks like. How do I fix this?
Solved by jmartt. Go to Solution.
Solved by user181. Go to Solution.
That might be from windows, minimize cad and go to your desktop and click in blank space and press F5 key to refresh.
https://forums.autodesk.com/t5/autocad-civil-3d-forum/file-path-stuck-on-screen/m-p/5802660#M282524
I don't get this any more with 2017, btw.
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the replies of @user181 and @jmartt suggestions work for you?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Hi @Anonymous
I just wanted to inform you that my reply cannot be the accepted solution. I have marked the solutions to your issue with the understanding that these are the correct answers.
If these responses did not work as solutions, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
However, I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns I am here to help!
