Drawing may need recovery
jayVVKFY
jayVVKFY
I am having trouble xref attaching an existing dwg file originally created using Carlson Survey software, into a new dwg file created using Civil 3D 2024.
I am able to open the Carlson dwg file using C3D 2024, but I am not able to XREF this file.
Every time I try to XREF the Carlson dwg file I get a message "Error: Unable to load file. Drawing may need recovery."
I have run audit and recover on the original Carlson dwg file, but that doesn't work.
Any ideas on what the problem might be?
tcorey
Can you Insert it?
Can you Attach and Query using AutoCAD Map? That's a commonly used way of bypassing drawing corruption, to capture those modelspace objects you want to save as a new file.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeew-m
Did you try the additional repair options listed HERE. ?
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
jayVVKFY
Thank you for the responses. I used the WBLOCK Purge process to repair the file.
One thing I'm curious about is why I'm able to open the file but not able to XREF the same file?
