- Mute
- Permalink
- Report
This morning my drawing all of a sudden started giving me the Windows Blue Ring every time I open the drawing. I've replicated this problem on two other workstations here.
Things I have tried already to troubleshoot this:
Validate Data Shortcuts
Audit
Recover
Purge
-purge regapps
Rebuild Data Shortcuts folder from scratch
Save As Data Shortcuts folder to a new folder
Save As drawing as a 2010 / 2013 DWG
None of these solutions has solved the problem unfortunately.
Once I load, if I wait until the Blue Ring appears and then I hit escape, I can draft normally.
However, this is a particular problem because are using Sheet Set Manager and due to this error I cannot print any of the sheets associated with this drawing using Sheet Set Manager.
Any help would be greatly appreciated.
