Dragged state does not survive insert, copy+paste, bind xref
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Drawing A contains cogo points, whose labels have been moved into a dragged state.
If you do any of the following actions, the labels will reset back to the non-dragged state.
- Copy and Paste drawing A into another drawing (if you paste as block, explode it)
- Insert drawing A into another drawing and explode it.
- Xref drawing A into another drawing and then Bind it, then explode the block.
This loss of the dragged state also happens for Parcel area labels. This is a problem because we might have multiple users each working on an area that contains Cogo points, then when they are all done, they need to combine these separate DWG files into one. "Pinning" the labels does not help.
On the other hand, alignment station labels, pipe network structure labels, pipe network pipe labels, and alignment station/offset labels RETAIN their dragged state. C3D is not consistent, unless I'm missing something here.
Drawing A
New Empty Drawing - after inserting Drawing A
TIA
