Dots appear in linetype when adding a Y offset
lstrubleWYCZW
Observer
Observer
lstrubleWYCZW
Observer
Observer
I am trying to modify a linetype for a tree row. It is basically a repeating series of arcs. I want the treerow edge to appear where the survey shots were taken, not extending farther out.  I added a Y offset so that the outer edge of the arcs are on the survey points instead of the back side of the arc.
The linetype creates the below figure. It has a dot at the repeat location of each arc. I want to remove the extra dots and just have the arcs. If I remove the Y offset the dots disappear and do not seem to be a part of the line.
Below is my code
*TREELINE_L0.5, Tree Line left side HALF SIZE
A,0,-.065,[TREE,AECCLAND,s=.065,Y=-.065],-.065
*TREELINE_R0.5, Tree Line right side HALF SIZE
A,0,-.065,[TREE,AECCLAND,s=.065,Y=.065,r=180],-.065
Any help would be appreciated. Thanks
tcorey
This:
A,0,-.065,[TREE,AECCLAND,s=.065,X=-0.065,Y=-.065],-.065
yields this:
I added an X offset to the linetype so that the top quadrant of the arc obscures the dot.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
lstrubleWYCZW
Observer
Observer
Thanks!
I had myself lost in the weeds when the solution was so simple
