I am trying to modify a linetype for a tree row. It is basically a repeating series of arcs. I want the treerow edge to appear where the survey shots were taken, not extending farther out. I added a Y offset so that the outer edge of the arcs are on the survey points instead of the back side of the arc.
The linetype creates the below figure. It has a dot at the repeat location of each arc. I want to remove the extra dots and just have the arcs. If I remove the Y offset the dots disappear and do not seem to be a part of the line.
Below is my code
*TREELINE_L0.5, Tree Line left side HALF SIZE
A,0,-.065,[TREE,AECCLAND,s=.065,Y=-.065],-.065
*TREELINE_R0.5, Tree Line right side HALF SIZE
A,0,-.065,[TREE,AECCLAND,s=.065,Y=.065,r=180],-.065
Any help would be appreciated. Thanks
Below is my code
Solved by tcorey. Go to Solution.
This:
A,0,-.065,[TREE,AECCLAND,s=.065,X=-0.065,Y=-.065],-.065
yields this:
I added an X offset to the linetype so that the top quadrant of the arc obscures the dot.
This:
yields this:
Thanks!
I had myself lost in the weeds when the solution was so simple
Thanks!
