Hello everyone,
Is there a way to divide or split a surface in 3?
Please and thank you!!!
Roger
Hi @arpenteur
Unfortunately there's not a tool that will simply do that. It really comes down to all the data defining the surface. That data could need to be split / divided as well to perform it.
The simplest solution would be to create an outer boundary on your surface, then make another with same data and a different boundary.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
If you can't or won't recreate it all from scratch to accommodate the division, then probably best to make 3 boundaries, and paste the original overall surface into three new separate surfaces and apply one of the boundaries to each.
