Displays multiple Surface elevation in a band of profiles
Oliver_C3D
Oliver_C3D
Hi Everyone
How can I display all surface elevations in one band when I have 2 or more Surfaces in a profile?
But in the band only elevation takes a surface?
tcorey
Add multiple bands of the same type and pick different surface profiles for the Profile 1 and Profile 2 in the different bands.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeew-m
This would help you.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Oliver_C3D
Hi
@tcorey
@Jeew-m
I have two Surfaces in the profile and I want to show the heights of both Surfaces in one band in the Ground Elevation band.
tcorey
Post your drawing.
Tim Corey
Redding, CA
Jeew-m
It seems like you have 3 profiles in the drawing, two surface profiles, and one design profile.
Using normal band labeling you will only add two profiles to the band.
You can try two things.
1. Create a new surface--> paste both surfaces on to new surface --> create surface profile for new surface
However, this may not be fully accurate depending on your surfaces.
2. The other thing is to add an optional band to the profile view to show the second surface profile.
Jeewana Meegahage
Design Engineer
