Displaying Cut/Fill Using Volume Surface Analysis
tgreeneWA89M
Message 1 of 8
tgreeneWA89M
I'm trying to find the volume between two surfaces, which I have done successfully. Now, however, I want to display which areas of the surface are cut and which are fill. I've watched the volume surface tutorial, and I've been all through the forum. Nothing I do plots the green and red on the surface. All I see is a translucent white surface. Does anyone have any suggestions?
Replies (7)
Message 2 of 8
wfberry
If you had posted that drawing it would probably be an easy fix.  IF this translucent white surface is a true surface, just change the style and use contours.  A "0" contour is 0 cut or fill.
Bill
Or post your drawing
Message 3 of 8
tgreeneWA89M
Here is the drawing. The red and green are the existing surface contours, the purple and blue are the proposed contours, and the translucent white surface is the volume surface I created between them. I'm not sure how to change the surface style; I'm new to Civil 3D. I thought I was doing it, but then nothing happened.Stripping Image.JPG
Message 4 of 8
wfberry
Well, that is not a drawing, it is just a picture.
Sorry
Bill
Message 5 of 8
wfberry
OK try this:
Have your Properties window opened.
Select your surface.
The second line of the Properties line should be Style
Select different versions that are available with the dropdown.
Bill
Message 6 of 8
igi_pop
Hey!
Do a surface elevation analisys with 3 intervals:
<0
0
>0
Then, make the surface style so it displays ELEVATION analisys.
That should take care of your problem.
Cheers,
Igor
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Message 8 of 8
Mohamed32Samy
Hi dear
i do 2 interval =0
or 3 interval =0
