Civil 3D Forum
Display Manual Superelevation in Bands
1 REPLY 1
Domziman
140 Views, 1 Reply
Hi guys is there a way to display the LH / RH lane slope in your profile view bands without using the superelevation. The problem i am facing is that the superelevation bands only display the info if the superelevation is calculated. with the new edit corridor transition you can easily create manual superelevations but i cant find a way to sidplay this in the bands the way superelevation does.
Civil 3D Certified Professional
Labels (1)
1 REPLY 1
ecfernandez
in reply to: Domziman
Hi @Domziman. It is pretty interesting what you are trying to do, however, I couldn't find an option to achieve it in C3D.
A workaround for this would be to get a points report (NEZ) along the Edge Of Pavement, and later compute the superelevation values on a spreadsheet. Then, you can create a polyline from the end result that represents the superelevation values of your corridor. I do this for existing corridors' superelevation, but I think it might work in your case also.
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Rail Community
