A Client wants to have a drawing showing existing level, proposed level and level difference (green +ve i.e. fill and red -ve i.e cut) and I can't think of the best way to produce this.
My only thought is to extract labels on a grid for each of the surfaces and use a different style for each with an appropriate "Y" offset to avoid overlaps
Can anyone think of a better solution?
Neil
neilyj (No connection with Autodesk other than using the products in the real world) Did you find this post helpful? Feel free to Like this post. Did your question get successfully answered? Then click on the ACCEPT SOLUTION button.
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW) Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD 64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Are the colors supposed to be shading or the color of the text? If it's the text. There is a way to make a label that will insert text at a standard height or a miniscule height based on a test. So you could have two texts in the label. But one would be too small to see.
It's been so long since I've done this. I don't remember the steps. I'll see if I can come across anything on it.
So by Googling "Civil 3d label use an expression to control text size". I got this in the AI Overview.
In the Expression editor, write a formula that uses an IF/THEN/ELSE statement to control text height based on an object property. For example, to set text height to 0.1000" for a specific condition:IF({Surface Elevation}>1000, 0.1000, 0.0500). You can also use properties from theInsert Propertylist.
That could be used to test against a volume Surface for above or below zero.
This "Civil 3d Volume surface label red or green" got:
In Autodesk Civil 3D, volume surface labels typically usered forcut(negative elevation values) and green forfill(positive elevation values). You can set this up using label styles and expressions that assign colors to the label components based on the surface elevation's sign, with cut values displayed in red and fill values in green.
Setting up Color-Coded Cut/Fill Labels
Create a Volume Surface:First, create a volume surface that compares your base surface (existing ground) and a comparison surface (proposed design).
Create Expressions:
You'll need two expressions to control the visibility of labels based on cut or fill conditions.
One expression, e.g., "Cut Text Height," will set a visible text height for cut conditions.
Another expression, e.g., "Fill Text Height," will set a very small (almost invisible) text height for fill conditions.
When you place a label in acutarea (where the surface is negative), the red cut label will be visible.
When you place a label in afillarea (where the surface is positive), the green fill label will be visible.
The other label's text will be present but nearly invisible due to the small text height assigned by its expression.
Allen Jessup CAD Manager - Designer Did you find this post helpful? Feel free to Like this post. Did your question get successfully answered? Then click on the ACCEPT SOLUTION button.
I make a label style with two text components placed at the exact same location and value content, one for cut and one for fill. One is colored red and the other is green. Use the draw order to place the green (fill) one on top of the red (cut) one. Edit the properties of the green one to not show when the value is negative (hide negative value). This makes the green one turn on and off as the value goes from positive to negative. When its positive the green value shows and covers the red value completely (they're the same value) When its negative the green one doesn't show and reveals the red value.
Hi All, Putting my thoughts in to this excellent discussion.
I am thinking of spot elevation on a grid and earthwork plan production to achieve this task.
For this we need 2 surfaces EG and FG
We need a spot elevation style that support a reference surface.
We create spot elevation on a grid (Remember the grid boundary) and for one elevation we give EG and for the next elevation (That comes from reference) we set FG.
Now there is a option in Civil 3D Earthwork plan production. You need to run this at this grid you used earlier.
It gives the cut and fill in two different texts. Which can be customizable easily. However this earthwork plan production is not dynamic.
@MMcCall402@Pointdump@AllenJessup@Cadguru42 - thanks for the replies but I already have suitable styles to show red and green labels (and have had them for some time—based on the methods you have suggested)
@Jeew-m the style with two labels (one from ref surface) looks like a good start. I've never had much luck with the earthworks plan production—in that the volumes are totally incorrect compared with surface analysis—but may just give it a try.
I can always extract spot level labels from a volume surface (based on the same grid) and have the levels display on the opposite side of the label point to the existing/proposed levels
Neil
You can add surface references to a surface label. One label on grid >> select similar >> properties >>choose the surface desired
Joe Bouza Did you find this post helpful? Feel free to Like this post. Did your question get successfully answered? Then click on the ACCEPT SOLUTION button.
Thank for all the responses - I did try the multiple label approach but eventually went with the earthworks plan production method as suggested by @Jeew-m.
I used a 20m grid spacing as below and changed the colours—the volumes produced by earthworks plan production are still unusable (grossly inaccurate) but the labels are spot on.
Yes I was pretty much at this stage and it is indeed more dynamic than the earthworks plan production—I shall probably create some specific labels that I can add to our template as setting them up and getting the alignment right takes a bit of trial and error.
