Hi!
I have a drawing with about 10 layouts. In some of the layouts some of the viewport have disappeard. When I hoover over the layout tab I can see the viewport, but when I open the tab it doesn't show. I have turned on and unfrosen all the layers, unfrosen all viewports.Any solutions?
ps. I made a screencast but I dont know where it is in the world 🙂
Solved by AllenJessup. Go to Solution.
Hi
I have done that but it didnt help. I have been working on thet drawing and plotted pdf before. But then the viewport was gone in many of the layouts.
I, too, did not see any viewports in the Paper Space tabs. (only at the bottom of the sheet.)
The xref's &/or images wouldn't load for me, which made me think if those images were placed in paper space of each layout tab versus creating a viewport in paper space to show the images from model space.
-Just a thought.
But you are right. When hovering over the tabs at the bottom, the images appear.
The image seen hovering over a tab is not "live". It's a stored raster as is the preview seen in various methods of opening a drawing file. So the image may show things that are no longer there.
Allen Jessup
CAD Manager - Designer
The only way I know of at present is to use the LAYDEL command and delete the layer the viewports are on. That will delete viewports in multiple layouts. There may be a couple of other ways I don't know of.
Allen Jessup
I tell the people I work with that unless I install software that records every keystroke and mouse click there is often no way to tell exactly how something happened. If it's not a recurring problem I want to fix it and move on. If something happens once in one drawing it's because of an error. Either on the users part of the programmers part. If it's unusual enough that I've never seen it happen before and if it doesn't happen again it's not something you're going to solve.
Allen Jessup
@Dexterel wrote:
By "no longer there" you mean like I said deleted :D?
Deleted, no longer XRefered, broken DRef, missing FDO. It was there and now it's not.
Allen Jessup
