DISAPPEARING VIEWPORT TEXT
dagee9ANG2
Message 1 of 16
dagee9ANG2
I am running Civil3D 2023 and fully updated. Why is it in the 2023 version does the model space text disappears during panning and zooming in the paper space viewport. I have to regen every time to get the text back and it is very time consuming.
Replies (15)
Message 2 of 16
tcorey
AECCLABELOPTIMIZE = 0. (Disables the new feature)
This is a new feature. It works like LevelOfDetail, but for labels.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 16
dagee9ANG2
this is turned off and the text is still dissapearing.
Message 4 of 16
tcorey
AeccLabelOptFlags = 1.
Tim Corey
Redding, CA
Message 5 of 16
J-Porter
I had a similar issue in which the grading optimization was the culprit.  We had to uninstall the grading optimization tool and the text then appeared fine.  Still unsure as to why this is the culprit.
Message 6 of 16
dagee9ANG2
No change with this one as well
Message 7 of 16
J-Porter
Can you post the drawing so I can test on my end.  Let's see if it happens for me too.  If it does then we can definitely point it to 2023.  If it doesn't then we may need to research possible issues on your system or network.  Also, what is the text font with which it happens?
Message 8 of 16
dagee9ANG2
J-Porter
I'm sorry I can not post any drawing.
It seems to be and in the annotate. I am unable to flip or reverse any of my line bearings and distances while in a viewport but it works in model space. I have tried the AECCLABELOPTIMIZE to on and off and the AECCLABELOPTFLAGE at 0 and 1 and no change. I did a clean uninstall and reinstalled and updated Civil3d. Cad is installed in a stand along computer drawings are stored elsewhere.
Message 9 of 16
J-Porter
Ok, no problem.  I understand.
So is this happening for everyone in the office or just you?  If not everyone, then can you open the drawing in question on another "working" computer and test.
Is this happening in all drawings or just one specific?
What is the build of the software?  To find this, please type in ABOUT at the command line and hit ENTER.  Then post the a screen capture of the box that appears.
Message 10 of 16
brennonneff
Have you tried setting the 'AECCVIEWPORTOPT' command to OFF? I believe this setting has something to do with a new feature mentioned by @tcorey in a previous post but is exclusive to label visibility in viewports.
Best of luck.
Message 11 of 16
dagee9ANG2
Brennonneff
Thank you, that seemed to have worked
Message 12 of 16
michaelYKAB5
Observer
Observer
I was having the same issue and this did the trick. Thanks
Message 13 of 16
AdevriesNPA4S
@brennonneff Thank you! this has been driving me crazy and this fix worked for me!
Message 14 of 16
gdiceA5BVP
Community Visitor
Community Visitor
Another thing Autodesk created that literally no one asked for. Thank you for the fix
Message 15 of 16
tcorey
@gdiceA5BVP   I have to disagree with you. Autodesk's largest customers wanted this functionality.
Despite the fact that this feature often causes alarm, when you don't know about it yet, it is useful in reducing how long it takes for Civil 3D labels to be regenerated.
Tim Corey
Redding, CA
Message 16 of 16
J-Porter
Let's also remember that Autodesk doesn't make a change for the sake of change.  All changes come from input from their beta testers (of which anyone can take part) and their wish lists (AKA the AutoCAD AUGI wish list as well as the Civil 3D Ideas forum).
