Civil 3D Forum
Disappearing Feature Lines
53 REPLIES 53
Message 1 of 54
Christie.G
5415 Views, 53 Replies
I have read a number of forum post regarding disappearing feature lines, but have not had any luck finding a solution. Is there any progress on preventing this from happening as I have read on the posts that this has been a problem since 2007 and every version since.
This is a very costly problem due to time spent reconstructing the feature lines so if there is a fix or a way to prevent this happening could we please get an update.
53 REPLIES 53
Message 41 of 54
ODO18
in reply to: TimYarris
That sounds on par.
Use the feature line as corridor feature as intended and it causes an error. Not sure why it took 4 years and me providing 3 videos and example drawings for you to finally figure it out...but good job. I will believe it is fixed when I see it.
Message 42 of 54
C3D_TomR
@TimYarris
I can’t consistently reproduce this error and it might not be related but I’m sharing here since it’s also FL related.
Editing a drawing with different versions of Civil 3D (2018 and 2020, for example) results in FLs added to surface not updating surface after changes are made to the FL even using rebuild or rebuild automatic. You have to remove the FL from the surface definition and add it back for the surface to update.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 43 of 54
C3D_TomR
in reply to: C3D_TomR
@TimYarris
I checked with a user from another firm for confirmation on this one. Neither of us has had this issue for years now when we do one specific thing: delete Site1 and create a new site from scratch for FLs.
Tom Richardson
Twitter | LinkedIn
Message 44 of 54
TimYarris
in reply to: fcernst
Hi @fcernst,
Mine is just one example of a workflow to reproduce the issue. We still have the examples you provided and will refer back to them as we continue research. Thanks again for providing them -- we need as many scenarios and data we can get.
Message 45 of 54
TimYarris
Hi @C3D_TomR. We've been researching a similar issue, where feature lines in the same site weren't updating a surface or corridor they were included in. Thanks for bringing it up.
Message 46 of 54
samir_rezk
on a positive note; I wanted to add, that I have not experienced the disappearing Feature lines issue with Siteless Feature Lines! Hopefully others can concur and I am not just getting lucky 😉
Samir Rezk
Technical Support Specialist
Message 47 of 54
keith
in reply to: samir_rezk
I too have found that making my feature lines "Siteless" seems to improve their longevity. To be honest I also created fresh templates for my firm since the old ones had been around forever and were likely riddled with errors and corrupt. Since our finished surfaces tend to get a little complicated and our sites rather large I have been devoting a separate drawing to the surface and then using data links to bring it into our production drawing. This all has seemed to work pretty well in alleviating the disappearance problem. Hope this helps.
Message 48 of 54
C3D_TomR
@TimYarris
We've experienced some issue with FLs not updating the surface unless we remove them from the surface and add them back. One suggestion made was to make sure the drawing isn't being edited in different versions of the software (2018 and 2020). I thought I would mention it here for reference. I can't confirm that is the cause of the issue, but something worth considering.
Tom Richardson
Twitter | LinkedIn
Message 49 of 54
ODO18
in reply to: Christie.G
Ok I believe I can safely say this has been resolved in 2021 as long as you put feature lines used as a corridor on SITE NONE and put the Corridors on SITE NONE.  I have done a trial in 2021 C3D using their default Template where I have removed/added/moved PIs and EPs, broken FLs several places, and joined them back together.  Doing all of that editing I audited and closed several times and the feature lines did not disappear and the most errors I got when auditing was 1 but mostly 0.  The corridors would update as the lines were edited.
Now I did do one thing that seemed to kill it.  I rejoined the feature line into one complete closed feature line afyer it was broken into pieces.  This has caused an error where the Corridor gets pulled down to Elev. 0 in several spots.  Rebuilding/deleting/replacing the corridor and surface did not fix it.  The last resort that usually fixes FLs that are having major issues is to move it to another site and then move it back, but trying to move the FL causes the file to lock up and crash every time.
So in summary, if I can grade with corridors now and edit the feature line all I want with the only two stipulations is that the Corridor FLs need to be on Site NONE and that I cannot join the FL into one complete FL once it has been broken, then I consider that a solution.
This is a very powerful grading method and I look forward to implementing it at my Company.
I have attached the file with the grading working fine (Grading Test 2) and then one with the corridor going to Elev 0 after rejoining the FL (Grading Test 1).
Message 50 of 54
@vaughan.giles7AGEV
Yes. This exactly. If my daylight line touches my footprint line (i.e. where the "grade to existing surface" changes from cut to fill), then it will without fail disappear after closing and reopening the drawing or moving the feature lines to another site.
Message 51 of 54
9 Months on, has there been any official development solving this issue?
Has there been any progress to recreate the issue on Autodesk's front?
With the work-around of using no sites, at least we have something - thanks @ODO18. I haven't tested this method however, as I don't want to risk the possibility of losing work again!
Message 52 of 54
I received an update via a new Beta if anyone wants to try and is part of the beta testing service.
Civil 3D 2020.6 Update Beta 3 (Build 3862):
Sounds like progress to me!
Message 53 of 54
chriscowgill7373
in reply to: ODO18
Supposedly the 2021.2.1 update for Civil 3D that was released on June 7 resolves the issue of the feature lines disappearing when they are on a site.  Supposedly also the 2020.5 update also resolved the same issue in that version.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 54 of 54
Rail Community
