Announcements
Dialog boxes are not saving last input/information inserted
jaovl.jv
jaovl.jv
Hi everyone! My Civil 3D isn't saving the last inputs in the dialog boxes. I type and change every configuration, but when I have to close it and open again, everything I typed changed to a pattern configuration. It used to save, but now it stopped and I don't know what I did or how to make it work again. Would apreciate any help!
Below I posted screenshots showing inputs that I changed on a parcel dialog box and the pattern configuration showing up after I close and open it again.
user181
On the prospector settings tab right click on Parcel and choose Edit feature settings.  Then under general set Save Command Changes to Settings to Yes
cwr-pae
AS @user181 shows you can set individual features to remember last input, or you can set it for all features under Drawing settings, Ambient settings tab, General tree. After setting the overall as desired, individual features can be set to the opposite setting if so desired.
jaovl.jv
Thank you all!!!! Both helped a lot, now everything is saving as I desired 🙌
