Announcements
Converting ESRI ascii DEM to CSV for import into Revit
I am trying to find the best way to convert an environment agency DEM .asc file into a CSV format for import into Revit. Is there a way to do this using Civil 3D or any other autodesk products?
Any help would be greatly appreciated!
Hidden_Brain
you can create a new surface and add the ASC file as a DEM definition. once the surface is built, from the report toolbox, use Surface Points to CSV report.
I have just tried the method you mentioned but I get an error "Failed to execute 'surface points to csv'" any idea why this might be?
Pointdump
Sam,
Please post your data.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Hidden_Brain
There have been some recent threads discussing the reports not working in some instances, for example:
http://forums.autodesk.com/t5/autocad-civil-3d-general/civil-3d-2016-transportation-extension-issue/...
it appears that hard coding the report path as mentioned in the thread above has fixed the problem. Give that a try, I do not have access to C3D at the moment to run the surface CSV report, but has always worked for me in the past.
*Edit: worst case, after you create the tin surface from asc file, set it to a style to display only the surface points, then extract those points. then you can extract the xyz data from the points.
Hi
Im trying to make a surface in revit 2021, but cant figure out how to do it, the way you have explained. how do i create a new surface is it with points?, sorry if it is a stupid question, and where do i make the dem definitions to the ASC file, ?
thank you
Anne Sofie
I found out i needed Civil 3d 🙂 i can do it now
