Design Ribbon and layout tab
i was reading another post and there was a picture showing a design workspace and a layout tab on the design workspace for 2013 C3D.   My installation doesn't have a design workspace, so i'm wondering how many of you have this wordspace?
andrewpuller3811
I don't know about the design workspace, unless it is a custom workspace saved by a user/company, but there is a contextual tab called "layout tools" which comes from the map.cuix file supplied with civil 3d.
If your context ribbon states are on, then the layout tools ribbon tab will display when you switch to a layout, unless your map.cuix is not loaded or the tab has been removed from the map.cuix file.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
C3D_TomR
No Design ribbon tab for me either. It's probably a custom one such as the one that we use.
The contextual layout tab is only when you are in a layout similar to selecting an alignment and seeing the contextual alignment ribbon tab appear.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
I see what it is.   It only shows up when your in the planning and analysis ribbon and in layout paper space.
