description key editing
allywhite666
allywhite666
Is anyone else disappointed with the description key editor in C3D?
I have been trying without success to find an easy way to edit description keys, copy and paste keys and do simple tasks with them.
The key editor in C3D is horrible, I would much prefer to be able to edit the keys in excel.
I am able to import and export the files using Sincpac-C3D but once they are exported you can't edit them or do anything to them so this is only good for backing up.
some things that I find annoying are -
If I have 2 description key files and want to take a few keys from one and put them in another, I can copy them but cant paste them into the second.
If I want to find a key quickly in a description key file I cant simply type the first letter of the key and expect the editor to jump to it, I have to manually scroll through all the keys until I find it.
I think Autodesk needs to improve this feature, anyone else?
Accepted solutions (4)
Replies (74)
Will this work with 2021?
@GTVicthis is a great program I've used it with 2019. Many thanks for all your hard work!!!
llains
Hi, GTVic
Had the same problem and found this precious help from you. Many thanks.
Now.... Is it possible to Update this rotine to the 2023 version?
If it is, nice. If it isn´t, thanks any way...
Luís
rl_jackson
@llains,
Sincpac - Quux Software CA, LLC is updated for all current versions of C3D and information can be found at the link I have provided.
Rick Jackson
Survey CAD Technician VI
GTVic
I have updated this utility to work with Civil 3D 2019 - 2024
(July 2023) Note, I fixed the XML code so the plugin loads for 2023 and 2024. There is no change to the macro itself. Thanks to Jeff for noticing the error.
llains
Many Many Thanks GTVic. This solve me a Lot of "pain".
Wish you all the best.
Regards
Luis Lains
PS: Sorry the reply was to GTVic...
rtompkinsR48JL
Many thanks as well.
This is one of the best, no, this is the BEST tool to get your Description Keys setup.
This should be something that is included in C3D.
R
llains
Regards
Luis Lains
gherrmanRQ549
Vote for this capability on the Civil 3D Ideas board:
allywhite666
Hello Greg, this is no longer working in civil3D 2024 can you update please :))
GTVic
Can you provide some details. Did you try the updated ZIP with 2024 in the name posted last March?
GTVic
I've tested and it appears to work with 2024 no problem.
I've updated it to not display a .NET error if the Survey Prefix Database is empty.
It should be good for another year.
allywhite666
This new one did the trick, the previous one did not work on my system. Thank you, my hero! ❤️ ❤️ 🙂
DavidLoria
How do I use this?
GTVic
Your question is a bit vague but I have repeated the basic instructions here:
The ZIP file contains an EXE file:
  1. Run the EXE file once to install the macro
  2. Start Civil 3D
    1. Type PDKSCU to run the macro
    2. There is a help button that displays an html page (MHT file) with instructions
  3. Run the EXE again to uninstall
I  noticed the MHT file was not properly displaying one section so I've updated that here.
cdavis
This Tool is AWESOME. Autodesk, take note, this should be incorporated into your Civil 3D. I have gone through many Standards changes and updates to layers and codes, not just for my company, but I do this for our clients as well. This will make creating/updating new Description Key sets way easier/faster.
