Dell Precision 7510 issues
alex
Message 1 of 15
alex
new dell Precision 7510 laptop just downloaded civil 3d 2017.  panning and usage issues with software as the response is very slow.  i saved the .dwg (contains grading, alignments, surface, etc) to local c-drive and same issues.  whom can i contact at Autodesk with my computers service tag (JC4RR72) to begin to troubleshoot these issues?
thanks to all
Replies (14)
Message 2 of 15
AllenJessup
Are you on (Formerly Subscription) of Desktop Subscription (rental)?
If you're on the basic Maintenance plan you can start a Support Request online in the Subscription center. If you have a higher level such as gold or platinum you can call. If you're unsure on what plan or level you have. Contact your reseller.
Allen Jessup
CAD Manager - Designer
Message 3 of 15
ToddRogers-WPM
What video card do you have?  And did you disable the Intel HD card?
Todd Rogers
Civil Administration at Walter P Moore
Message 4 of 15
ToddRogers-WPM
I looked up your service tag and you have the AMD FirePro.  You need to disable the Intel HD Graphics.  Also in your BIOS, you will need to disable the Graphics Switching.
Todd Rogers
Message 5 of 15
alex
I have Firepro W5170M. I am working with Dell prosupport right now to make
the adjustments you suggested.
Alex Guillory, PE, CFM
Bluewing Civil Consulting, LLC
alex@bluewingcivil.com
337.802.9164 phone/cell
PO Box 3384 | Lafayette, LA 70502
License No. EF 5887
Message 6 of 15
alex
does Autodesk support AMD Firepro W5170M?  i have done everything directed in the previous email.  what is my next step?
Message 7 of 15
AllenJessup
Based on a Win10 OS. No. You can check HERE.
Allen Jessup
Message 8 of 15
alex
This says page not found
License No. EF 5887
Message 9 of 15
AllenJessup
Funny. Works for me. Here's the full link
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
Allen Jessup
Message 10 of 15
ToddRogers-WPM
Here's the link...
Todd Rogers
Message 11 of 15
alex
I am not able to select suite release year of 2017 as you are.
Can you send me the link to recommended hardware where I can select 2017? I
am trying to get a new quote from Dell
License No. EF 5887
Message 12 of 15
alex
would you mind speaking with me over the phone about this?  i do not want to order another computer from Dell unless i am sure what i am ordering will work with 2017.
337.802.9164
Message 13 of 15
ToddRogers-WPM
Since Civil 3D runs on top of AutoCAD, you select AutoCAD, 2017.  Here is a list of the recommended and certified graphics cards...
Todd Rogers
Message 14 of 15
Where did you locate this list, are you able to provide a link to it?
Message 15 of 15
AllenJessup
Select the appropriate options and you'll get a list.
Allen Jessup
