Delete polyline segment using trime command
bdimenna
Message 1 of 13
bdimenna
Anyone know the setting to allow using the trim command to remove entire polyline segments? ie the cutting edges are the node of the polyline itself
My system works as expected, but my coworkers system only removes what seems to be an arbitrary amount of the segment.
Replies (12)
Message 2 of 13
tcorey
If you want to use Trim, you must have cutting edges that run through the vertices of the polyline being trimmed.
You could use Break to accomplish the same thing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
jmayo-EE
Edgemode or trimmode
John Mayo
Message 4 of 13
SkipBurns
This sounds like edgemode.  If you select the polyline as the cutting edge though it should work as you say. Without selecting a cutting edge it will use everything and cut into little segments if edgemode is set to 1 (the extension of any object)
Message 5 of 13
Ranjit_Singh
You can simply control click a polyline segment and hit delete.
Message 6 of 13
AllenJessup
Nice one. I had forgotten about that!
Allen Jessup
CAD Manager - Designer
Message 7 of 13
tcorey
Holy smokes, Batman! I didn't know about this feature. That is pure awesomeness.
Just when you think you know everything....  😉
Tim Corey
Redding, CA
Message 8 of 13
bdimenna
I was almost positive I had tried toggling both of those both ways but something still wasn't right.  Anyways, his system behaves like mine now so when I try to show him how do draw something, it works as expected.
Message 9 of 13
bdimenna
I found out about the ctrl click accidentally once, it's a neat little feature.  I find it more useful though when trying to edit for example, one single station label of an alignment or some other group type element.
Message 10 of 13
Cadguru42
I've been using AutoCAD for 23 years and never knew about that.
C3D 2024-2026
Windows 11
32GB RAM
Message 11 of 13
Joe-Bouza
Smokin👍
Joe Bouza
Message 12 of 13
Ranjit_Singh
You are welcome Smiley Happy
Message 13 of 13
VGonsalves
Hi Ranjit
Is there a system variable that controls this function. I am currently using AutoCAD 2018 but have had no success using the trick that you suggested.
