Delete a specific frequency/station in corridor
raja_shahbazQN4N3
raja_shahbazQN4N3
i want to delete a specific station frequency in my corridor region,
as i show in screen shot. how i can do it.
m_kingdon
I don't think deleting a specific station is possible.  You could split the corridor region and use a different frequency within that region.
Mike Kingdon
Civil 3D Zealot
Jeew-m
If the frequency line is from the major frequencies you cannot delete it. For example if the frequency lines are defined by 10m interval you cannot delete a frequency line at 1+300.
Instead, what you can do is avoid that frequency line by altering the frequencies.
In this case you can split the corridor either side of the considered location and set a frequency that does not catch the station that need to be deleted.
For example, You can split the corridor at 1280 and 1+320. Then for the region 1+280 to 1+320 you can set frequency by 4.5m interval so that you never get a frequency line at 1+300.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
raja_shahbazQN4N3
yes i split the region. Now feature line are smooth in drainage channel.
