Define local coordinate system - what will the "map scale" actually do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've defined a local coordinate system using the MAPCSCREATE command.
On step 3a I chose "Create a new coordinate system from an existing coordinate system" and selected the correct UTM zone etc. that the local system was based on.
On step 3c I entered the combined scale factor in the "Map (paper) scale" field.
My drawing settings are set to the new local coordinate system.
As far as I can tell all of that is correct. My question is what will the "map scale" actually do? I tried an experiment xref attaching another file that has its coordinate system set to UTM (the same zone etc as mentioned in step 3a). When I checked the endpoints of some of the AutoCAD lines the coordinates are the same, meaning it did not scale the xref. So I am trying to understand when the map scale actually does something (like Map Query?).
I need to understand this better in order to frame my second question.
Thank you
John
