Civil 3D Forum
Default Contour Label Interval Setting
2 REPLIES 2
ronaldr
149 Views, 2 Replies
When using the "Contour - Multiple at Interval" option for adding contour labels. My system has a default interval value of 25 along the contour line. Is it possible to change this default setting to another value and if so, how would this be done?
Labels (1)
2 REPLIES 2
user181
in reply to: ronaldr
Go to the Settings tab of the Toolspace palette and expand Surface and then expand Commands and right click on AddContourLabelingGroup and select Edit command settings. Then under Add Contour Labeling you can change the interval.
ronaldr
Thanks, exactly what I was looking for...
Rail Community
