Hi all,
I am designing the 1 km road 18 m wide having attached assembly. After generating the Cross sections, the daylight (embankment fill slopes and Cut slopes) are not ending at the ground profile. (green line)
In corridor surface i used "Top links" then for boundry, i used "corridor extend as a boundry" parameter,
What could be the reason?
Please find attached images of Cross sections, Assembly, assembly properties and corridor properties.
Solved by nglatne. Go to Solution.
Solved by Kyle-Evans. Go to Solution.
Is the corridor itself extending out past the daylight? You did not include a plan view image of the corridor.
In my experience, Corridor Shrinkwrap does not work all the time, especially if you have a super detailed/long corridor. Can you post the drawing file?
As plan shows corridor isn't extending beyond the daylight . please find attached drg file.
Ok, I have figured it out. The shrinkwrap is not working because on your second corner, you have overlapping corridor lines on the inside of the turn. As seen in the event viewer also...
Simply make a new assembly that does not have any daylighting on the right hand side and apply it to that corner only.
Kyle
Hi Kyle, I founs the better way of doing it (removing overlapping of sample lines at corners, called "Bowties")
1) Eihter we can reduce the spacing of sample lines (while creating corridor, reduce the frequency distance). this will avod the overlapping and we can get the smooth corridor.
2) another way is using "Clear the Bowtie" command tool on a tool bar. or by selecting option "yes" for the clear bowties prompt in a Edit faeture setting of a corridor on a settings tab of a tollspace.
Path is "Settings tab, Corridor, Rt click, Edit feature settings, choose "yes" for Clear Bowties. then go to command line and type command "Forceeditcorridor" and select the corridor to be edited, the overlappings will be removed.
Thanx
