Civil 3D Forum
Daylight, conditional cut and fill assemblies
6 REPLIES 6
2870 Views, 6 Replies
I am beginer and i reffering the autodesk civil 3D course. I have a problem with subassemblies.
Can anyone clarify the difference between daylight subassembly , conditional cut and fill subassembly please.
6 REPLIES 6
Joe-Bouza
Joe-Bouza
I have more experience with the horizontal condition
The daylight sub assemblies perform the cut anf fill as prescribed.
the conditional subs do the same but have a true false condition the you can set,  if cut is < h apply this sub assembly,  if not use this subassembly and so on They allow you to evaluate the conditions along you corridor and apply the assembly desired.
Joe Bouza
Joe Bouza
Jeew-m
Jeew-m
This is in addition to Joe's comments.
Daylight is a subassembly that creates you cut fill slopes for your corridor.
Conditional cut/Fill means just two subassemblies which carry conditions with them.
They cannot function by them selves. They give a condition to daylight subassembly how it should be applied.
For example if you need to have a cut slope of 1.2:1 when cut height is less than 6m and 1.5:1 slope when cut height is greater than 6m you can use conditional assembly with cut.
This is a good example for that.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Jeewana Meegahage
Design Engineer
in reply to: Joe-Bouza
Thank you very much @Joe-Bouza and I appreciated your useful clarification. I have clarified the issue with your reply.
Thank you very much for your support.
in reply to: Jeew-m
Thank you very much @Jeew-m and I appreciated your useful clarification. I have clarified the issue with your reply.  and I am very happy when I got a reply from an expert from my country. It is very happy to see experts in this forum from my country.Thank you very much for your support.
Jeew-m
Jeew-m
You are Welcome.
Jeewana Meegahage
Design Engineer
You are Welcome.
Jeewana Meegahage
Design Engineer
LucieChartier
in reply to: Jeew-m
LucieChartier
How do I create a sub assembly that respects this? (see image)Cut condition.jpg
Rail Community
