- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. I'm trying to meet existing ground. I am using the DaylightInsideROW subassembly but I've tried others as well. Along the corridor in certain sections the surface I've created using the datum of my subassembly will extend beyond where it meets existing grounds, this happens on either one or both sides throughout. Sometimes it will meet EG and then stop like I want it to. I've set the Corridor Extents as the Outer Boundary. I've searched and searched the forum but I could not find someone with the same problem.
I have a single corridor and a single assembly. The assembly is pretty basic with 2 basic lanes, shoulders and the DaylightInsideROW subassemblies. I've attached a picture.
I've attached a couple of pictures of the issue occuring in one of the problematic sections. As you can see in the first picture the right side of the datum surface is meeting daylight and stopping, while the left side meets daylight and then continues on in a weird geometry before stopping at a random point. In the second picture the same thing is happening but on the other side.
Ultimately I'm trying to calculate the cut and fill volumes throughout the corridor.
Can any body help?
